Thanks for the info Ted, it was helpful.
We will be getting a coil trailer.
The straightener was mentioned and since we still have our teeth we will get one.
This job is on a military base and there is a little confusion as to who the responsible oversight will be, the Army Core Of Engineers or the Gas Company since we tie into there existing line. We are 10'-20' off of the road and bore under the road many times so DOT has a role in this even though it is on base.
Our specs are from the ACOE and are vague in some areas such as TTCP (temp traffic control plan),welding procedures and qualifications but it does fall under B31.8.
Tracer wire and marking tape are detailed. Wire after six inches of back fill and detectable marking tape (6" wide 0.004 thk) 12" below grade.
http://www.jmeagle.com/pdfs/2008%20Installation%20Guides/YellowGasDistTechIG_June%202008.pdfhttp://www.cpchem.com/hb/getdocanon.asp?doc=127&lib=CPC-PortalThese were two helpful web sites.
Did you always have to bring in sand for the initial back fill?
This is a sandy area (Sandhills)
I did not see that requirement in our specs.
It does specify that rock or debris must be removed.
