Up Topic American Welding Society Services / Certifications / CVN testing expiry
- - By Duke (***) Date 02-01-2009 16:22 Edited 02-01-2009 16:30
Do impact tests on PQR stay valid indefinitely? (D1.1)  A PM was reviewing some WPS for a current project, and they were qualified in 1999, and his question was, "don't Charpy tests expire after a while"?  I think not, and I cant find anything in '04 D1.1.  (my '06 and '08 are in the truck)
Parent - By 3.2 Inspector (***) Date 02-01-2009 17:25
Did he give a reason for his question?
It seem to be a very very strange question to me.
To answer your question: No a charpy test does not expire.
3.2
Parent - - By hogan (****) Date 02-02-2009 15:45
D1.5 lists 36 months for Fracture Critical and 60 months for all others. Maybe he got them confused.
Parent - - By 3.2 Inspector (***) Date 02-03-2009 10:00
So the test is not valid 60 months after it has been performed?
3.2
Parent - - By js55 (*****) Date 02-03-2009 17:25
I'd certainly like to hear the answer to that as well. As well as if anybody knows the metallurgical or mechanical justification.
Parent - - By HgTX (***) Date 02-04-2009 20:49
The D1.5 restriction means that yes, the test expires 60 (or 36) months after it was performed.
There's not a whole lot of justification for it.  There has been discussion of removing it.  But there's paranoia about removing it.
The only reason I could think of to keep it is that it's possible that the formulation of the consumables might have changed just a wee bit over the years, not enough to change classification, but enough to change performance.
My prediction is that the non-fracture-critical limit (60 months) will be gone by the next D1.5 edition or the one after that.  Fracture-critical (36 months), less likely.
Hg
p.s.  Note to those who recognize me:  I disagree with the requirement, but I plan to continue to enforce it; I go along with the AWS democratic code-writing process.  So don't get any bright ideas.
Parent - By js55 (*****) Date 02-04-2009 21:18
thanks
