Up Topic Welding Industry / Technical Discussions / Mig Al wire
- - By ashish jain 2 Date 02-11-2009 12:21
I have a 250 A 60% duty cycle MIG welder.Presently  using 0.8 mm M.S. Now I want to use 1.2 mm Al wire for a new job.
Will my machine work on 1.2 mm Al wire or I have to buy a new one for this capacity(I can not try it at my end because of cost of Al wire spool,teflon coated roller and liner )
Parent - By Kix (****) Date 02-11-2009 16:07
Yes, your machine will take the amperage you will put it through with 1.2mm wire very nicely.  You will need a push/pull gun or a spool gun for it to work though.
Parent - By DaveBoyer (*****) Date 02-12-2009 04:49
   As Kix mentions, a push/pull or a spool gun works the best. You have mentioned a teflon liner. If You use a regular push type mig gun with a teflon liner it must be a short gun/cable/liner assembly kept as straight as possible. Some use a straight gun instead of a gooseneck gun.
