I admit to not knowing that much about this and I need to polish up my interrogation tools because I didn't get much information to start with.
I got more now though...
Apparently, they are bearing surfaces for the axel of a Bobcat. The area worn is where the bearing races ride and they are really worn out. The material is cast steel--an assumption based on use and strength required for that use. The area that is worn has lots of 1/4" wide grooves that have worn over the 2" length of the circumference I am repairing, the depth goes down to 1" in some places.
I've decided to cut off the stub and machine a new one and weld that on instead of welding up the old piece. I'll machine a hole in the hub and put a shoulder on the stub so that it is centered correctly and weld the inside and the outside for strength. I'll be using TIG again and just 70S rod.
How do you tell for sure which type of cast material it is? Spark test, file test, educated guess? Good to know that the process that I was using was appropriate for cast iron but I need to know how to tell the difference for future possibilities.
As always, I appreciate your help and expertise.
Thx
