This may be of help. I made this as part of a lecture many years ago using the D1.1 and D1.5 as its basis
I had listed the code references that go along with the requested information on the documentation.
Enjoy
Type of Weldor (D1.1.4.1.2)(Manual or Machine)
Variables (D1.14 Part C.4.7 & 4.21 & 4.22 Table 4.11)(D1.5.5.24)
Material / Specification (D1.1 Table 3.1)(D1.5.5.21.3) To
Base Metal (D1.1.3.3)(D1.1.1.2 - 100 ksi yield limit)(D1.5.5.24.1.1 - 90 ksi yield limit)(D1.5.1.2.2 & 5.4.3 base metals)
Plate Thickness: (D1.1 Table 4.10)(D1.5 Table 5.7)
Groove: (D1.1.3.7.2)(D1.1.4.23 & 4.30)(D1.5.5.23.1.2)
Fillet: (D1.1.3.7.2)(D1.1.4.25 & 4.30)(D1.5.5.23.1.3)
Pipe Diameter / Thickness: (D1.1 Table 4.10)
Groove: (D1.1.4.26 & 4.30)
Fillet: (D1.1.4.30)
Joint Type (D1.1.3.9, 3.10, 3.11, 3.12 & 3.13)(D1.1 Table 3.7 & Figures 3.2, 3.3, 3.4, 3.5, 3.6, 3.7, 3.8, 3.9, 3.10 &3.11)
Process / Type (D1.1.3.2.3)(D1.1.Table 4.11 #1)(D1.5.5.24.1.2)
Backing (D1.1.4.19.1.2)(D1.1.Table 4.11 #6)(D1.5.5.23.1.2 & 5.24)___________Size (D1.1.5.10.3)(D1.5.3.13.4) __________
Position (D1.1.4.23.1 Table 4.9)(D1.5.5.24.2.2)
Weld Progression (D1.1.3.7.1)(D1.5.4 .6.8)
Filler Metal (D1.1.3.3)(D1.1.Table 4.11-Item 3)(D1.1.5.3.2.2)(D1.5 Tables 4.1, 4.2 & 4.3)
Specification No. / Class (D1.1.Table 3.1)(B2.1 Table C1)
F Number (D1.1.Table 4.11-Item 2 & Table 4.12)(B2.1 Table C1)
Gas / Flux Type (D1.1.Table 4.11-Note 2)(D1.1.4.22)(D1.5 Table 5.3 #13)__________ Flow Rate _____________
Electrode (D1.1.5.3.4)(D1.1.5.3.2, 5.3.2.1)(D1.5.5.24.2.1)
Single / Multiple (D1.1 Table 3.7)(D1.1.Table 4.5 #11 & 4.11 #7)(D1.5.5.21.2)
Diameter / Manufacturer (D1.1 Table 3.7) (D1.1.5.3.3.1)(D1.1.Table 4.5 #10)(D1.5.5.21.2)
Welding Procedure Specification No. (D1.1 Table 3.7)(D1.1.5.5)(D1.5.5.21.2)(D1.1.3.6) Rev.
Preheat (D1.1.3.5)(D1.1.5.6 & 5.7)(D1.5.4.2) Maximum Interpass Temperature
Stringer or Weave (D1.1.Table 4.6 #11)(D1.5.5.12 & 5.13 & Table 5.3)(see KJ inch heat input)
Current / Polarity (D1.1.3.6 Table 3.7)(D1.5.21.2) Volts ___________Amps____________ + or -Polarity_______
Travel Speed________ Rod Temperature (D1.1.5.3.2.2) (D1.5.4.5) __________CVN _________ F° ________ lbs
Minimum required KJ inch (D1.1.Table 4.5 & 4.6)(D1.5.5.12, 5.13 Tables 5.3, 12.3, 12.4 & 12.5)
(Volts x Amps x .06 divided by Travel speed = KJ inch) or (Volts x Amps x .06 divided by KJ inch = Travel speed)
Weldor Test Information (D1.1 Annex E Form E-4)(D1.5 Annex III Form III-4)
Name _________ ID # _________
Type of Weldor (D1.1.4.1.2)__________ Date of Test ____________
Variables (D1.14 Part C.4.7 & 4.21 & 4.22 Table 4.11)(D1.5.5.24) Record actual values used in qualification test
Current / Polarity (D1.1.3.6 Table 3.7)(D1.5.21.2) Volts_____ Amps_______ + or - polarity _______
Backing (D1.1.4.19.1.2)(D1.1.Table 4.11 #6)(D1.5.5.23.1.2 & 5.24) __________Size (D1.1.5.10.3)(D1.5.3.13.4)__________
Material / Specification (D1.1 Table 3.1)(D1.5.5.21.3)__________To____________Heat #_____________
Diameter / Manufacturer (D1.1 Table 3.7)(D1.1.Table 4.5 #10)(D1.5.5.21.2)
Filler Metal (D1.1.3.3)(D1.1.3.3)(D1.1.Table 4.11-Item 3)(D1.1.5.3.2.2)(D1.5 Tables 4.1, 4.2 & 4.3)
Gas / Flux Type (D1.1.Table 4.11-Note 2)(D1.1.4.22)(D1.5 Table 5.3 #13)_________ Flow Rate_________
Fillet: (D1.1.4.30)
Rod Temperature (D1.1.5.3.2.2) (D1.5.4.5)_________Wind (D1.1.5.12.1)(D1.5.4.14.3)________
Preheat (D1.1.3.5)(D1.1.5.6 & 5.7)(D1.5.4.2)_______ Maximum Interpass Temperature________
Ambient Temperature (D1.1.5.12.2)(D1.5.4.2)_______Weld Length______ Travel Speed__________
Appearance of welds (D1.1.4.8.1)(D1.5.6.26)(D1.5.5.21.5)(D1.5.6.4.4 Inspector observation required)
Root pass (D1.1.4.8.1-4&5)(D1.1 Table 6.1)(D1.5.6.26.1.2)(D1.5.5.21.5)
Intermediate passes (D1.1 Table 6.1)(D1.1.5.30)(D1.5.6.26.1.2)(D1.5.3.11)(D1.5.5.21.5)
Cover pass (D1.1.4.8.1)(D1.1 Table 6.1)(D1.1.5.24, 5.27 & 5.28)(D1.5.3.6, 3.8 & 3.9)(D1.5.6.26)
Undercut (D1.1.4.8.1)(D1.5.5.27.1)
Porosity (D1.1 Table 6.1)(D1.5.5.27.4.1)(D1.5.6.26.1.6)
Arc Strikes (D1.1.5.29)(D1.5.3.10)
Name of Welding Test Witness (D1.5.6.4.4 Inspector observation required)
