Up Topic Welding Industry / Welding Fundamentals / Stick welding without a stinger
- - By Metarinka (****) Date 02-12-2009 21:07
as we all know, just about any stick welder can also run stick, but why bother changing out the stinger when you can just jam it into your tig torch?
it was worth a chuckle. I've never heard of this before
http://www.weldingtipsandtricks.com/tig-welding.html
Parent - By Fritz T Katt (**) Date 02-12-2009 22:45
Erm, does it work? Pretty creative, or a spark of stupidity, can't decide.
Parent - - By tighand430 (***) Date 02-12-2009 23:35
It does work. I've done it a couple times when the stinger wasn't close by an it was just for a small weld. Wouldn't recommend doin it for a long time tho.
Parent - - By Superflux (****) Date 02-13-2009 01:02
What shielding gas do you recommend for that rod????????????????/
Parent - - By raftergwelding (*****) Date 02-13-2009 15:01
i went to do a lil side job once and didnt have enuff lead to reach so i used my jumper cables just like Mcgyver
Parent - - By Metarinka (****) Date 02-18-2009 07:33
I mean people have used everything from microwave transformers to car alternators, if it can hold the amperage it's a stinger in my mind.  Then again I would be weary about holding an unshielded jumper cable aligator clamp. It's very hard to undue an aligator clamp when you're actively being jolted
Parent - By raftergwelding (*****) Date 02-18-2009 14:20
my clamps were insulated
Parent - By OBrien (***) Date 02-19-2009 01:40
Propane at a minimum but acetalyne works best.
