i had a similar problem w/ an automatic helmet. there were dark spots all over the lens and it wouldn't turn on. i'm not sure what exactly happened, but i'm pretty sure i accidently left it in my car when the temperature was around -10 F. but, to answer your question, no, i haven't heard of any repair shops anywhere. i think the best you could do is send it off to the manufacturer and let them make the decision to fix it or throw it away...maybe it's still under warranty and you'll get a new one for free!
I have a SPeedglas XL and mine did the same thing. You can call a local welding supply store and they can give you the number for Hornell. I doubt that they will be able to fix it unless it's just dirty. They're not sure if they can fix mine either. I can't believe that they can't "fix" them anymore...They're sticking to the 9000 series and they suck.
Regards,
John
