Hi folks!
I'm interested in making some furniture for home out of wrought iron and ceramic tiles (end-tables), plus there's some small repair tasks where I believe that I just need to learn to weld. I've read all the material I can find on the Internet about how to get started. (I want to learn this for occasional home use, not a career, btw.) I need some advice from you folks. Questions below:
1) Looks like a small flux-core wire arc welder would be the best choice for a beginner. (Local Lowes has one for about $200.) Sound about right?
2) Are there dangerous gases released from flux-core wire welding? Do I need to worry about ventilation? Obviously, I need to wear a mask and protective (insulated) gloves for welding, but is a ventilator or dust mask really needed?
3) Would the small (I think it was 70-80 amps, runs off 115V normal house current) welder I mentioned in #1 above work well for making some furniture frames out of metal?
4) Would this welder also work well for repairing slightly larger steel or aluminum items, like lawnmower parts, steel-legged work-tables, metal pick-nick table, etc.?
5) Any suggestions on books or other web-sites that may have good educational info for a beginner? It seems this flux-core wire welding is a reasonably new concept, and I really haven't found a lot of info about it on the Web.
Thanks in advance!
Dave
