Reference AWS 2008 D1.1 Figure 6.11 "Hole type IQI or Wire IQI on source side may be placed anywhere along the joint.
Reference ASME Section V:
(d) IQI Placement for Welds -- Wire IQIs. The IQI(s)
shall be placed on the weld so that the length of the wires
is perpendicular to the length of the weld. The identification
numbers and, when used, the lead letter "F," shall not be
in the area of interest, except when geometric configuration
makes it impractical.
Reference B31.3 2006
344.5 Radiographic Examination
344.5.1 Method. Radiography of castings is covered
in para. 302.3.3. Radiography of welds and of components
other than castings shall be performed in
accordance with BPV Code, Section V, Article 2.
Dunno where you read that, but it's not required in any code I am aware of.
