Up Topic Welding Industry / Technical Discussions / P1 to P9
- - By mightymoe (**) Date 02-20-2009 01:02
What filler wire should be used to join the materials using the tig process?
Parent - By GRoberts (***) Date 02-21-2009 21:27
It depends on the service environment, PWHT temperatures, etc.  The P9 needs PWHT at a higher temperature than the P1 (if the P1 is of a thickness or service environment where PWHT is required).  You may have to butter the P9, PWHT, then weld to the P1.
