>> Concerning your electrode question. As it was told to me years ago, there are only a couple of mills that draw the wire because it's really the same material. The wire is then purchased in bulk spools to other companies such as Murex and they straighten, cut to length, and apply the coating. It's the coating that causes the changes in metallurgy and arc characteristics. So maybe your engineers are only partly right! Must be each of the electrode companies have a little old lady with a secret flux recipe. Interestingly, Murex E7016 was what I had to test with on open roots when I started school. Well, apparently the little old lady must have died and took her recipe with her because in the mid 60"s their E7016 went off the market-period! Dow went to Airco and their E7016 was crap. It had a harsher arc and it was a porosity making phenomenon. It was banned from use in the whole plant. We then went to Lincoln E7018 as well as Alloy Rods Corp. and McKay (a little later)and the rest is history because they became the standby. We all shed a tear when the old Murex disappeared because it had the nicest, softest arc you ever saw and always burnt off square. It was one sweet rod to use!<<
