Hi All!
I live and work over the water in the UK and was amongst the first to use FCAW in power station repair work. At first, all was good, everyone came to see main steam header's welded up very quickly and the client was happy! No repairs and good heat inputs! Then every tom, dick and harry was filling and capping with flux cored wire on anything above a certain size, with very little training, if you could MIG weld then you could use FCAW?! All of a sudden, the repair rate shot up, due to lack of training and poor selection of welders trained to perform these high quality welds! Also, it must be said , down to the increase in poor wire that flooded the market.
I am no longer welding for a living but based in an office and still get negative feedback about FCAW, and no matter how hard I proclaim its virtues, I still get a negative response.
Nanjing, both ELGA and METRODE produce a FCAW welding wire that is stress relievable, the ELGA one, I have just finished a contract on a major LNG project and can confirm works as stated!
