Up Topic Welding Industry / Technical Discussions / Welder Qualification
- - By DanWatanabe Date 02-26-2009 16:45
If a welder certifies on a standard 1/2" thick fillet weld test, is their minimum dia. pipe restriction for his qualification?
Parent - - By ravi theCobra (**) Date 02-26-2009 16:49
Min  Diameter   is   24  "
Parent - By DanWatanabe Date 02-26-2009 18:53
Is there anywhere in D1.1 that specifically states limits or is this an inference? If we look at B2.1 it specifically states qualification of fillets on pl. are restricted to 24" dia. pipe. Thanks for your comments
Parent - By ctacker (****) Date 02-26-2009 16:56
Yes, and the diameter Limit depends on which code your working to!
Parent - - By spots (**) Date 02-26-2009 16:59
Per AWS D1.1
I agree, the minimums are 24" and 1/8" wall thickness
See note g, two plates are required 3F and 4F
Parent - - By DanWatanabe Date 02-26-2009 18:54
Parent - By kipman (***) Date 02-26-2009 22:32
Dan,
Look at Table 4.10.  A fillet weld test on plate qualifies a welder within the process and position tested for only fillet welding on structural plate and tubulars.  There is no diameter restriction, but Note h applies which means there is a dihedral angle limitation.
Mankenberg
