Up Topic American Welding Society Services / Certifications / AWS D1.1 Fillet T-Joint Prequalification
- - By pmipmbok Date 03-02-2009 06:58
Dose AWS D1.1 -3.9 Fillet Weld Requirement- Include Fillet T-Joint Prequalification?
Parent - By BryonLewis (****) Date 03-02-2009 14:04
I don't believe that fillets are prequalified.
Parent - - By swsweld (****) Date 03-02-2009 16:52
As long as you meet the requirements of Table 3.7 you are good.
Figure 3.2 shows a prequalified fillet weld T-joint on tubular steel.
Figure 3.11 shows Skewed T- joints that are prequalified.
3.9.1 doesn't exclude the T-joint.
Parent - - By pmipmbok Date 03-03-2009 04:29
My Joint Is Non Tubular Right Angle T-Joint
And I said Your Comment To My Client But He Didn't Accept
Do You Know How I Can Give Acceptance From AWS?
Parent - By DAYANARA (**) Date 03-03-2009 23:06
Dear
I think you shall see 3.9.1
Only you shall Know table 5.8 for minimum fillet welds, figure 2.1 and 2.4 for design and tabla 3.7  for weld type FILLET.
Dayanara
Parent - By swsweld (****) Date 03-04-2009 04:27
pmipmbok,
2.2.5.2 (2006)states that fillet welds between parts...at an angle between 80-100 degrees, shop drawings shall show fillet weld leg size.
Figure 3.11 details prequalified skewed T-joints from 60 to 135 degrees. The fillet weld between 80-100 degrees would apply. A T-Joint is a 90 degree connection
3.9.1 doesn't exclude the T-joint it only gives limitations on the lap joint Fig. 2.1 and min. lap in Fig. 2.4
3.9.3 Skewed T-Joints falls under 3.9 Fillet Weld Requirements
Hope that makes sense. IMO the T-joint fillet weld is within the prequalified WPS requirements.
