Billy,
That's correct. You need the high frequency in combination with AC to weld Aluminum. With the high freq., you won't be scratch starting your arc. With the AC, the arc switches from + to - 60 times a second, depending on the frequency, 60 representing a 60 hertz power supply.
During the moments in between switching, there is no welding arc. I think the high frequency is an essential item for doing AC tig Aluminum. You also need the AC because it provides a cleaning action as it rapidly switches back and forth. I believe the cleaning action is removing Aluminum oxide, which forms instantaneously as the Aluminum is exposed to the oxygen in the air. As with other film protected materials, the oxide film that forms melts at a considerably higher temperature than the base metal. The AC helps to remove the oxide film, and the shielding gas keeps it from reforming by protecting it from the atmosphere.
I'm not sure if a square-wave( a supposedly instantaneous switching takes place) machine eliminates the need for the high frequency during switching or not, as I believe they came about to avoid the momentary power loss and difficulty reestablishing the arc.
But with the advent of all the new kinds of power sources, there may be something out there to replace AC for Aluminum. Maybe someone with more knowledge of the new power supplies will post something.
Hope this helps.
Dale Simonds
If this is the case, spend the $$ and buy a GTAW machine. You can DC weld the alumiunum with the right gas mix and technique, note this is not for a novice.
Your trying to get caviar with pizza $$.
Spend the $$ now and buy a used peice of GTAW equipment you won't outgrow any time soon. You can also stick weld (SMAW) and some will accommodate a "spool gun" wire feeder as well.
DGXL,
I'd be interested in hearing more about the DC Aluminum . Are you refering to a He/Ar mix? Or something more exotic?
I never had much luck with DC Aluminum. Isolated cases, such as the last day of a shutdown situation, 1 piece of handrail to fix, only DC machines available, scratch start GTAW torches, and straight Argon, that sort of thing.
Dale Simonds
Dale and DGXL,thanks for the info and help.you guys have made up my mind for me.i am going to buy the GTAW machine.your help and time is appreciated..i'm sure i will be posting more questions when i get this thing to the shop..you guys have made my first visit to AWS a great one.by the way--any thoughts on welding 4130 chromoly tubing?thanks again billy
Hey B,
You don't ask for much do you? ;-]
DC GTAW is done on a daily basis in the aerospace/aircraft industries on nonferrous materials. You wouldn't have much luck with pure Ar. Yes a mix is used, typically with helium. Heavy weldments are easily joined without any preheat depending on the alloy. Beads are nice, fine with a good appearance and deep penetration.
Billy,
Check the Technical section, page 2. "Welding 4130 Chromemoly".
You might also try the search option.
Good luck.
DGXL,
Thanks for the info.
Dale Simonds
By -
Date 01-14-2002 18:28
DCEN welding of Al is possible, but you need to treat the Al properly to remove the oxide scale, and weld it quickly thereafter to ensure that you weld before the scale re-forms.
Typically the oxide removal is done by a pickling treatment. This is not really an option for someone without the fancy baths and solutions.
While a fancy gas mix will obviously increase the heat of the arc, which is always a bonus when welding Al, the use of a hotter gas in itself will not make Al welding substantially easier with DCEN.
Niekie
