Up Topic Welding Industry / General Welding Discussion / carbide welder
- - By jerry bass (*) Date 03-05-2009 02:42
Anyone ever heard of a carbide welder. I acquired one today that is very old. It is mounted on a cart with iron wheels
Attachment: welder002.jpg (502k)
Parent - - By OBrien (***) Date 03-05-2009 02:48
Not I.  Could you post some pictures.  Im just curious but what did it run you?
Parent - - By jerry bass (*) Date 03-05-2009 02:53
I got in a package deal with some other stuff. I dont have any pics yet (its too dark). It looks like a tank (about 15 or 20 gallons) with a lantern type device on top. All mounted on a cart with iron wheels. It has a place for a bottle of some kind it looks like
Parent - - By James Corbin (**) Date 03-05-2009 03:26
FYI - The reaction of calcium carbide with water was discovered 1862.
CaC2 + 2H2O → C2H2 + Ca(OH)2
This reaction is the basis of the industrial manufacture of acetylene, and is the major industrial use of calcium carbide.
Do you have any idea how old it is?
Parent - By Metarinka (****) Date 03-05-2009 06:59
you rehearsing for a job with the antiques road show?
Parent - - By jerry bass (*) Date 03-05-2009 23:43
It looks very old. It has an emblem on it that says FM. Also, an emblem that i cant read. I'm going to try to get a pic of it later and post it. Im not interested in using it. I was just wondering if anyone knows anything about it and how much its worth
Parent - - By mongoose52 (*) Date 03-05-2009 23:59
[deleted]
Parent - By G.S.Crisi (****) Date 03-06-2009 21:19
It doesn't sound like an acetylene generator, it IS an acetylene generator. When I was a boy (60 years ago) it was in wide use in shops that carried out oxyacetylene welding.
Givoanni S. Crisi
Parent - - By DaveBoyer (*****) Date 03-05-2009 05:18
If You try to use that thing You have bigger balls than I have. Altho they can be operated safely, they can go BANG too.
Parent - By TozziWelding (**) Date 03-06-2009 00:35
Might be an acetylene generator, uses calciume carbide and water to make the gas. Same as a miners lamp.
Parent - - By phaux (***) Date 03-07-2009 15:37
Post some pics, interested in seeing what it looks like.
Parent - By Northweldor (***) Date 03-09-2009 12:28 Edited 03-09-2009 12:37
Here are some pics of a 1924 portable model with a glass carbide receptacle (not sure that this would be a good idea, although you would know if you had enough carbide to finish the job!).
http://home-and-garden.webshots.com/album/94673964cjPxoT
And here are some pics of modern versions.
http://www.iigas.com/ACETYLENE.htm
