That town Gonnadragup was named after a guy I worked with who on the last job (prior to getting to the one I worked with him on)...
1) never had a bad shot, (except for those few times when companies made him use bad gas, wire, base metal, or unstable electrical current )
2) was told by the QC that was one of the slickest he'd ever seen
3) Never busted a test (except for those items noted in # 1 and a run in with an inspector that actually knew what the code said)
4) Was leaving the current job just as soon as he got them out of a hole and got the RT percentage up.
His cousin IMa Goldenarm was single handedly responsible for making 1 CS 6" pipe weld in an 8 hour shift. he could have done it faster but there was a shortage of new cardboard on the job and he was having a hard time finding a good spot to kneel down NEAR THE JACKSTANDS ! Not to mention the guy that tacked it up on the prior shift forgot to wire brush his tacks after feathering them down.
Yall have a good one.
Gerald
