I'm a big fan of Ed's site, and often go there when I need aluminum data before qualifying a procedure. That guy really knows his stuff.
PipeIt, I use 92-8 in all my steel machines. It allows a full range of transfer mode, and in spray it's smooth as glass. I have been here for two years; the company has been using the mix for about 4 years now. They went through an extensive (and grueling) trial process, and came away liking the 92-8 best. For what we do here, it is the best choice. You may need something a little different, depending upon your normal operating values. If you stay in spray transfer 100% of the time, you need a very high argon content. Like those before me, I think you definitely want to look at your operators; cleaning, fit-up, manipulation, and machine settings. Good luck.
Thanks we are trying out some 85 15 and the guys really like it.
bozaktwo1,
Good advise. Once you have your base-metal, filler, gas, and amp/volt all set where you want there is typically only one variable left. That is mill scale. When working with GMAW solid wire (spray) the mill scale seems to have more of an impact than anything. There are fillers available that deal with this better than others. But there is nothing better than totally removing it from the weld joint. Time and time again mill scale has caused a process that is running great to go into the toilet. In my shop I have all CJP welds, other than static, that are made with GMAW to be blasted prior to fit up. Maybe it is as little over kill but it has cut down on not only NDT reject but minor discontinuities as well.
Progressive quality
I would like to work for you Hogan
Anytime, I think I would learn a lot from the experience.
