In addition to what bryon has stated, try not to think of a "T" fillet as having a root. As you have stated you can put two pieces together to form a "T" and then fillet weld them together. While this connection has a root, don't think of it as you would a CJP. Think of it more as just naming the location of the first pass(root pass). It is the intent of the code that these two pieces should be in intimate contact. The section that byron has listed allows for some tolerance for this. You may not always be able to bring the two plies into intimate contact. So the code allows you to have a 3/16" gap for material under 3", but it also requires that if your gap is over 1/16" you shall add the size of the gap to the size of the fillet. There is also no requirement for the base-metal to be prepped (beveled like a groove weld). Hope that helps.
