![](/mwf/attachments//avatars/13260-9338.jpg)
I received a preq WPS from a vendor and as I was reviewing it, I saw that the process was GMAW-S. So I went to the code and started looking to make sure. In the list of welding processes per sec 3, it has, SMAW, GMAW, FCAW-G, FCAW-S, and GTAW, but no GMAW-S. Above the processes it says (see 1.3.1) which gives you a list of acceptable processes that can be used with this code. At the bottom of the clause, it says (Note: any variation of GMAW including short circuit transfer, is acceptable. So I'm confused.
Thanks, Ray C.
