Up Topic Welding Industry / Technical Discussions / PROBLEM OF BEND FAIL IN SS410S WELD OVERLAY
- - By jaspaldhesi Date 03-23-2009 09:05
I AM DOING SS410S WELD OVERLAY ON SS516 CARBON STEEL PLATE WITH BARRIER LAYER OF E309LMo  IN FLAT POSITION. i am unable to clear the bed test neither in FCAW nor in SMAW. the carbon % restriction is 0.06%.
Please help me out.
The overlay height is 6mm.
Parent - - By defaced (**) Date 03-23-2009 14:01
We're going to need some more details.  Where is the weld failing, is it at the fusion boundary or in the weld?  What's your welding sequence?  What parameters are you using?
Parent - By js55 (*****) Date 03-23-2009 17:11
PWHT?
