I learned on the R2 units. They are heavy as hell. In the field, every time you plugged one in you had to, hit the start button, check the rotation, unplug them, rewire if rotation was wrong, what a pain in the butt. I burned one up that way. Had to drag those damm things all over Lockeed and Genral Motors plants in southern Ca. Also saw an apprentice drop one off a flat bed, completely destroyed it, put a dent in the asphalt. Great memories. God I must be getting old. Thanks for the pics.
