Up Topic American Welding Society Services / Certifications / CAWI
- - By Cody T (*) Date 03-29-2009 17:32
How does one start his path to become a CAWI? Go to the seminars? Buy books? I am curious.
Parent - - By BryonLewis (****) Date 03-29-2009 17:59
To start the CAWI path you have to take the CWI exam and not pass with 72% but you need at least 60%.
Parent - - By Cody T (*) Date 03-29-2009 18:42
What are the materials that you have to study, I've looked at several links that people have given me and I found there are quite a few books, Do I need to purchase those books?
Parent - - By BryonLewis (****) Date 03-29-2009 19:00
Look at the materials that are given out with the seminar.  That would be a good place to start.  You need to decide which code you are going to test to and get that book well in advance.
Parent - - By Cody T (*) Date 03-29-2009 20:55
Do you also strongly suggest going to all 3 of the seminars?
Parent - - By BryonLewis (****) Date 03-30-2009 00:25
I picked up some things that I didn't get in my own studies and I could ask questions that helped me with other areas that were a little gray in my comprehension.  So if you can afford it I would do it.
Parent - - By Cody T (*) Date 03-30-2009 00:26
What are some of the things that I have to know?
Parent - By BryonLewis (****) Date 03-30-2009 01:01
Page 8 on this link will give you the general body of knowledge for the CWI tests.
http://files.aws.org/certification/CWI/CWI_Exam_only_pkg.pdf
Parent - - By Joseph P. Kane (****) Date 03-30-2009 10:16
Cody T
This is a very inauspicious question!?!?!?!?   A CAWI is a person who fails the examination or who is otherwise unqualified to perform inspection!
Now,Why would anyone like to know how to fail?!?!?
It appears that you did not read the AWS B 5.1 Qualification Document that Bryon Lewis posted for you, nor the AWS QC-1 Certification Document.
This is not a good way to start!
Joe Kane
Parent - By 803056 (*****) Date 03-30-2009 12:47
No one, and I mean no one wants to be a CAWI unless you they don't have the required relevant work experience. The CAWI can not work, i.e., perform inspections, etc, unless there is a CWI present to supervise and within audible hearing distance.
As Joe mentioned, the CAWI is typically someone that failed the CWI.
Parent - By Cody T (*) Date 03-30-2009 22:47
Well I am sorry. I did not know where to start. And I did read those documents.
