Up Topic Welding Industry / General Welding Discussion / potentionmeter/ rheostat
- - By TRC (***) Date 04-01-2009 21:08
What is the differance between a pot and a rheostat? Could a pot replace a rheostat at very low current? Thanks- Ted
Parent - - By DaveBoyer (*****) Date 04-02-2009 03:28
I don't see why not, many years ago they were all wire wound, the low wattage ones just had finer wire. Just mind the watt rating.
Parent - - By TRC (***) Date 04-02-2009 09:27
the pot has 3 wires and the reo has 2- why? the current in this application is .003 amps
Parent - - By DaveBoyer (*****) Date 04-03-2009 02:34
A pot or rheostat can have 2 or 3 wires, each end of the resistance element and the wiper. If there are only 2 wires it is one end of the resistive element and the wiper. The only real difference is that an old fashioned rheostat has a wire wound element, and a more modern pot has a carbon element.
Parent - - By TRC (***) Date 04-03-2009 09:18
someone told me to bridge the center post to either one of the outer post and that it will do the same thing as a two wire rheostat would do, is that correct?
Parent - By DaveBoyer (*****) Date 04-04-2009 02:36
Yes, check with an ohm meter to see which posts to use. One will increase resistance when turned clockwise, the other will decrease when turned clockwise, choose what suits Your aplication.
