What more would you like to know? It works (like a light bulb) the same as the welding process, difference being you have to much mass to melt rapidly.
The current you would use is the secondary side of the transformer and will work just like the engine driven machine.
Yes but beware, Aluminum is a very good heat sink and has a very low melting temp, and you need to find away to make connections with out arcing. I don't recommend using the primary switch for that task.
