Up Topic Welding Industry / Technical Discussions / ISO 5817
- - By 100perpen (*) Date 04-23-2009 11:58
Has anyone had any experience with ISO 5817. We are bidding a job requiring ISO 5817 application. My impression is D1.1 acceptance levels are the same but the terminology is different. For example the 5817 has B, C and D levels of acceptance and D1.1 has clause 6 inspection criteria. Am I wrong to say D1.1 criteria meets the ISO 5817 criteria?
Parent - - By Shane Feder (****) Date 04-23-2009 12:28
100perpen,
ISO 5817 is "Quality levels for imperfections in fusion welded joints in steel, nickel, titanium and their alloys."
That is a lot different to a structural steel code.
The only way you will find out is to compare the acceptance criteria from both codes.
Regards,
Shane
Parent - By 100perpen (*) Date 04-23-2009 12:41
Thank you Shane.
I am in the process of acquiring the ISO standard for comparison.
