I have a 1970 sa-200. armature has new shunts and exciter brushes. Motor has new rear seal the crank has been turned to 30,000 on main journels and 20,000 on rod journels. new pistons and piston rings. the pistons are standerd size, the cylinders have been honed and was showing no dents in cylinder walls. also has new oil pump and bearings for rods and crank. head has been shaved and new head bolts were used. The paint job is have @$$, i got ripped on it. frame, gas tank and generator housing is painted gloss black. the doors and hood is flat black. also have a spare hood for the machine. needs new face plate. The only thing i am waiting on is the condencer and end cap for the mag. the mag has a new coil in it. new plugs in the motor and new fan belt also. new thermastat also. has a pig tail for a remote hook up. please call me anytime for questions. the machine is located in central louisiana. will take a trade on a 200d or 300d in good welding condition.
call me on 713-824-1983 name is tyler
