Dave, the next thing to check is your actual amperage output. I had a new Lincoln with a 20 hp. Honda and the RPM's were not set high enough. This created an output problem. Another time one of my employees did not know to turn the fine adjustment knob up all the way for full output. The idle increase may be a governor problem. I own several gas drive welders and they are all 100% duty cycle and considered industrial machines. Every diesal I have ever seen was a heavy duty machine and they all put out very well. When you finally figure it out, would you please post the problem.
Mike Sherman
Shermans Welding
By -
Date 02-11-2002 05:47
I would tend to think that it is your welding machine. I use my Trailblazer 251nt quite often with 6010 and 7018, and I don't have a problem with the arc at all. It is a 3 phase welder, but I don't think that should make too much difference. I do have 75 foot leads that are 1/0 in size. Maybe your wire is too small, but then again, you might just have normal wear on the machine.
A good rule of thumb that I figured out just by doing some comparisons with an oil change on my generator and that of a car goes something like this: My manual says to change the oil every 50 hours for my welder/generator, and you are supposed to change the oil in your car or truck every 3000 miles. Do the math and 2800 hours on a machine is equivalent to about 168,000 miles on a car or truck. You also mentioned 4800 hours on another machine. That would equate to about 288,000 miles. Sure, I know diesels go further, and this might be a lame comparison on my part, but that is the way I look at it when it comes to engine driven welders. Lets face it, you admit yourself that it's old and has a fair amount of hours on it. Things do wear out and need replaced. I'm not saying you need to replace your welder, but you might just need to have it looked at by a reliable welding, full service company, if nobody here gives you a good "tip" that would lead you to the exact problem . Better to spend a little $$ and find out its just a $50 part or fix, than to spend a couple grand on a new one and find out the old one just needed that $50 part.
Hope this helps.
Slagman
