We have some aluminum lithium alloys that we are looking to experiment with. I know that they need some sort of back purging, but someone recommended using a "hard purge." What is that referring to?
This will be for a circumferential joint. Is this comment above referring to the fact that just sealing the part and pumping it with gas purge is not good enough and that we'd need some sort of hard fixture?
Thanks
