Up Topic American Welding Society Services / Technical Standards & Publications / Heat treat D1.1 '86
- - By ctacker (****) Date 05-06-2009 20:11
I have a job spec calling for heat treat per section 4.4 D1.1 '86, holding time per table 4.4.2.
I don't have access to '86 code book. can anyone tell me if there is a difference in d1.1 5.8 '08 and table 5.2 '08 that would change the way its done from the '86 year book?
Parent - - By swnorris (****) Date 05-07-2009 15:12
My '92 is different from the '08, so the '86 would most likely be different than the '08 as well.
Parent - By Bill M (***) Date 05-07-2009 16:57
If it helps - I have a 1990 D1.1 copy.  Section 4.4 is stress relief heat treatment
Attachment: 1990D1.1page.PDF (183k)
Parent - By 3.2 Inspector (***) Date 05-07-2009 17:05
Buy the 86 version?
3.2
Parent - By hogan (****) Date 05-07-2009 17:48
They can be found at a good price from a used technical bookstore.
Parent - - By rickc (**) Date 05-07-2009 18:30
Section 4.4 is on page 48 and Table 4.4.2 is on Page 45 of D1.1:1986 and they are a little different from the current edition. Here's the different lines from Table 4.4.2 for example:
Over 1/4" to 2" - 1 hr/in.
Over 2" - 2 hrs + 15 min for every inch over 2"
...and Section 4.4 is about half a page but, more than I'm going to type out. You can buy it at https://www.awspubs.com/product_info.php?products_id=770
I wish they made historical editions available in PDF ...and for less money. I don't suppose you could talk your customer into using current industry practices/standards?
Parent - - By ctacker (****) Date 05-07-2009 19:27
Thanks everyone, if we get the job we will be getting an '86 version. I appreciate all the help!
Carl
Parent - - By HgTX (***) Date 05-08-2009 17:45
Have you considered an RFI asking about using current codes?
Hg
Parent - By ctacker (****) Date 05-09-2009 01:01
The job is getting estimated, I told our estimators to put latest edition of D1.1 for heat treat. the drawings also called for welding to be done with E7018. I also told them to say on the bid that all welding will be done with E71T 1. I think the drawings need to be updated. All material is A36 so I cant see any reason for not allowing us to do it that way!
