K,
I was waiting to see who else would respond to your post. I thought there would be many hits on this subject.
In the eighties I was GTAW my first nuclear-application manifold of some sort using 347 SS. When I put a piece of rod (filler metal) on the steel bench, then the inspector would walk up and toss it. Many TIG welders hold filler rod in their mouth's when positioning parts, etc. He would discard these as well. I finally figured out he could toss as much rod as I could chew, and he would always be there when I did. Had to learn my table manners the hard way. Had no idea at the time why he kept taking my rod.
Who knew...
Kulkarni,
Upon Niekie3’s answer to your question, you mentioned in your reply-
“I was curious about their actual need and whether it is the standard/norm in the pressure vessel industry.”
To answer your question from my experience with my former company as an Owners, QA Rep. and as a vessel fabricator/welder, the answer is no! It is not the standard/norm in the pressure vessel industry. The plant site where I worked contained hundreds (possibly more) 300L series pressure vessels built by outside vendors as well as internally fabricated. Few required passivation/pickling and fewer (that I observed) were built with specialized fabrication tooling (SS hand tools as an example). Few specs require, likewise vendor and company shops voluntarily institute, clad rolls, special shears, SS platens, SS stock racks, SS clad power head jaws, SS clad rollers, etc. unless specified/required to do so. Many (not all), out-of-hand will use SS clad ½ clamps, SS nuts & key-plates, SS shim stock, and nylon lifting straps as a few examples.
As Niekie pointed out, the severity/criticality of the intended service and the environment in which the vessel is set, is what governs the engineering design specifications. The specifications are what are supposed to govern the inspector as well! It’s been my experience managing inspectors that it’s easy for an inspector with the best intentions, to apply requirements (or his personal interpretation of industry standards) that he possibly used on another project to the one at hand without conferring with the design engineer. This is all too common of a problem that causes considerable conflict and loss of productivity, which translates to a higher cost to the customer, and possibly a loss of a client to the vendor.
As an example, I had a new (just left my orientation), contracted inspector provided by a noted international inspection agency, literally jump out of my truck, rush up to a fitter who had a SS elbow clamped in a cast iron/steel jawed vise. He made a heck of a scene and rejected the fitting because of not having brass jaws in the vise and was in the process of rejecting the entire project. He’d never seen the project’s specs, he just assumed they were the same as some other company’s he’d worked for sometime in the past!
Regardless of what we as construction participants think is right or wrong, specifications are specifications and the documented history of a company’s specific operations speak volumes of what works and when it doesn’t!
