Same here.....just have to use some common sense. If you have large areas to repair, it may be best to repace it, however for small cuts, nicks, we repair it with tape or heat shrink. The idea is to prevent dragging a damaged lead across the material on our tables and having it arc somewhere and hurt someone or possibly damage the equipment.
