Mike,
Confused again about your response to the definition or function of the trim control on your feeders and controllers.
I thought the frequency was the pulse rate (PPS) value in the set up menu. Was also told by one of Miller's former employees this value was basically arc voltage. As this value is increased, the arc voltage increases (as noted on a calibrated test instrument). The "noise" (don't want to start more controversy with the terminology) increases in pitch, which is indicative of the frequency increase. But the display also shows a rise in voltage as well.
An increase in the trim also resulted in an increase in the arc length and vice versa, this time indicative of an increase in arc voltage.
