What effect does Manganese have in Iconel 625? The nominal composition in this alloy is 0.50%. If the as welded deposit is significantly higher (ie. 2.5% Mn) how would this effect the mechanical and corrosion resistance properties of the as welded alloy compared to the nominal composition 625 alloy?
