Yes thanks DGXL, I have looked into that. Seminars are not until May. I was really looking for an answer on the board.
If I have a 6000 series T4 aluminum coil that has just had its first step (called heat-treatment or sloution heat-treatment) and has done its week long strenghtening period termed as "aging or room temperature precipitation" (at the rolling manufacturer), what is the allowable amount of time from leaving the mill to factory floor must it be put through the press?
Many alloys approach stable condition at room temperature, but some alloys, particularly those containing magnesium and silicon or magnesium and zinc (6000 series Mg&Si), continue to "age-harden" for long periods of time at room temperature. If it was to graphed, would the curve be exponential? What is the storage time alotted for a coil prior to being pressed and welded? Is there a cut off?
