Up Topic American Welding Society Services / Certifications / AWS D1.1 Qualification for materials groups
- - By HOTPASS Date 05-24-2009 15:25
HI All,
Does anyone know how the groupings work are worked in the welder qualifications in aws d1.1?
If you weld a group 2 what does that qualify you for?
Where in AWS can you find this info'
Parent - - By strat (**) Date 05-25-2009 20:32
Hey HOTPASS,
Im gonna give this a shot, if i'm wrong someone please reply
This is out of AWS D1.1 2006 if you go to section 4 Part C Performance Qualification 4.21, The welding personnel shall follow a WPS applicable to the
qualification test required. All of the WPS essential variable limitations of 4.7 shall apply
4.7.3 Base-Metal Qualification. WPSs requiring qualification that use base metal listed in 3.1 shall qualify other base metal groups in conformance with table 4.8
Table 4.8 shows you the base metal combinations allowed by pqr
so in short if it is a prequad wps and you test out from a group II then you are certified in the base metals of group I and II
Someone else please respond
Strat
Parent - By jarcher (**) Date 05-26-2009 03:57 Edited 05-26-2009 04:07
Check 4.22 and Table 4.12. Base material is not listed as an essential variable for WPQR's, so any material that a WPS can be written for under D1.1 can be qualified for a welder by one test. Of course a WPS must exist for each material, but a welder is considered qualified to weld under that WPS if it matches the WPQR qualifying WPS on essential welder variables. See 1.2 for material limitations.
Parent - By Kix (****) Date 05-26-2009 12:36
Material grouping is not an essential variable for welder qualification, so it doesn't matter what you test your man on.  For procedure qualification, that's another story.
