Up Topic American Welding Society Services / Certifications / D1.6 WELDER QUALIFICATION,3G GROOVE WELD
- - By SLFAB Date 02-21-2002 13:11
IF A WPS IS MADE FOR GROOVE WELD 1G,2G & 3G.ACCORDING TO TABLE 4.4 PERFORMANCE QUALIFICATION A WELDER OPERATOR MAY TEST IN 3G ONLY, AND BE QUALIFIED IN 1G,2G & 3G.AM I CORRECT?
Parent - - By Wildturkey (**) Date 02-21-2002 14:31
you are correct. a 3G position will qualify a welder welding Flat, Horizontal, and Vertical on plate. just make shure you read the notes for pipe
Parent - - By DGXL (***) Date 02-26-2002 04:02
The welder is qualified as stated above, in the 3 positions.
The WPS is qualified for all positions in accordance with 4.1.7.
Parent - - By bmaas1 (***) Date 02-27-2002 07:02
Where does it state that the wps is qualified for all positions? Curious.
I can't locate 4.1.7. Need help.
Thanks,
Brian Maas
Parent - - By Wildturkey (**) Date 02-27-2002 12:30
Brian,
Are you looking at the AWS D1.6 Code? I have the 1999 edition and 4.1.7 states "Qualification of WPS's for CJP groove welds in any position listed in 4.1.9 qualifies for all positions". 4.1.9 refers you to Figure 4.3 for test positions. Any of those positions qualifies the WPS for all positions.
Parent - By bmaas1 (***) Date 02-27-2002 16:06
Thank you.
