Been watching this thread with interest and a good amount of confusion.
I never understood this.. Maybe this is hijacking a thread.. Maybe it fits..
Every top flight poster here would say that it takes a PQR and some very specific controls in place to weld over Galvanized or painted metals... But what exactly are those if they are not a thin rust inhibitive coating.????????
Paint, Zinc, WD-40.. all thin rust inhibitive coatings.
How thin is thin?
Lots of things inhibit corrosion, many of them are based on hydrocarbons or other enemies of steel.
Don't like to be a synic but weasel words like "thin rust inhibitive coating" leave way to much to the imagination.
Well we diddn't mean paint or galvanized when we said "thin rust inhibitive coatings"....... Ok than what exactly is ment??????
By jrw159
Date 06-03-2009 19:56
Edited 06-03-2009 20:15
Lawrence,
I believe it fits perfectly and is, IMHO, not a hijack. I am sure most here know how I feel about welding through "coatings" and I truly see your point.
jrw159
Lawrence,
My take is - if you weld it and don't get defects, then it's a "thin, rust inhibitive coating". If you get defects, then it's paint and you should'a ground it off first.
I know - big help I am.
If You develope a procedure, follow it, test the parts and they make all the mechanicals, what would it matter if the material had been coated with peanut butter? [to be sarcastic] I understand Your point and agree.
Joe,
I called AWS and asked to speak to someone specializing in coatings. I spoke extensively with this person and then I sent him all the info I had on this product and requested that he e-mail me back after reviewing the documents. Here is the response I received.
"To document our earlier conversation, D1.1 does not forbid welding over products such as this, and specifically recognizes "a thin rust-inhibitive coating" (see D1.1/D1.1M:2008, 5.15).
You may use a prequalified WPS such as the one you forwarded below, although I too would recommend qualification testing to minimize the risk of rework. You may ask Atlas for their recommendations regarding consumable *brand names*, and you may also wish to do some welder training. Note that the current for the 0.045 wire should read 230 to 280.
As I mentioned, I am currently working on a new publication ... AWS D3.9 "Specification for Classification of Weld-Through Paint Primers" which should be published by the end of the year.
If you go ahead with the epoxy powder coating, I would be interesting in hear your results."
You are correct that AWS does not list by product, just description.
jrw159
