Up Topic Welders and Inspectors / Welding Equipment Classifieds / 20' Factory Built Goosneck, $2000.00 Dickson, TN 37055
- - By hillbilly (**) Date 06-03-2009 00:39 Edited 06-03-2009 02:46
$2,000.00
615 557-8706
I've outgrown this trailer. I'm going to upgrade to a dual tandem goose with alittle more deck and a larger GVW.
This is a factory built gooseneck. i have a TN title for it. 20'8" long deck, 8'6" wide. 7k pound axles, with working brakes. I just put a new 2" oak floor in it around a month ago, it's been treated with burnt motor oil and diesel fuel. 5' ramps, 2 new tailights. 8 "D" rings, 4 on each side for tie downs. it does have a few running lamps that need replaced. Tires are worn, but they do the job. I priced new 10 ply trailer tires here in town the other day, for $99 dollars apiece, mounted and balanced. It could use a paint job. Some of the pics are of before the new floor was installed. Pics are in the links posted below
http://i157.photobucket.com/albums/t74/HillbillyFAB/GNpics006.jpg
http://i157.photobucket.com/albums/t74/HillbillyFAB/GNpics003.jpg
http://i157.photobucket.com/albums/t74/HillbillyFAB/GNdeck.jpg
Parent - - By Partagas (*) Date 06-03-2009 01:53
Pics do not work.  Might want to check it out.
Parent - - By hillbilly (**) Date 06-03-2009 02:36
thank you. i'll see what's going on with them.
Parent - By DaveBoyer (*****) Date 06-03-2009 02:55
The pics worked for Me now.
