Up Topic American Welding Society Services / Technical Standards & Publications / A242 (Type 1) Material?
- - By kkidd1 Date 06-03-2009 17:17
A242 at one time was listed in D1.1 as a prequalified base material, Group 2 I think. I don't see it listed now. Can some one help me out with this?  I have a job that requires a242 (Type 1) HIGH STRENGTH SELF WEATHERING STEEL.  Can some one help me with this.
Thanks.
Parent - - By rickc (**) Date 06-03-2009 18:23
Yep, sometime between 1992 and 2000 it got dropped as a prequalified material. If you were to use it now you would have to run a coupon using it as an unlisted material
Parent - - By kkidd1 Date 06-04-2009 10:51
Thanks Rickc. Do you know why they droped this material? I still have jobs out in the field that we used prequalified wps's on back in 1996 - 2000. I wonder what the problem was?  It would be interesting to know why they changed this.
     Thanks gain
Parent - By rickc (**) Date 06-04-2009 18:59
Not a clue. We were in a similar boat when they dropped A514.
FWIW, you're old procedures are still good under the current standard by 4.2.1 on Page 124 of D1.1:2008.
