I have a question about butt welding of cold rolled carbon steel strip (W= 5 cm, T= 1.5 mm) that work as a big spiral spring.
I want to know how I can give information about Welding Process, WPS and PQR of butt welding of this strip.
I want to know about related standards and codes.
One of my important necessaries is: This weld shall not be fractured at weld line under cyclic fatigue load of this spring (Fracture should take place at base metal).
Can we weld this strip by TIG and it qualified?
Thanks for your help
Best regards
moso
