By 803056
Date 06-10-2009 20:17
Edited 06-10-2009 20:20
There are a number of things that can magnetize long slender materials like pipe, rods, etc.
The Earth's magnetic field can induce a residual field in the material if it was shipped in a northerly-southerly direction. The tendency is stronger as you reach the northern or southern latitudes. Likewise, stacking the pipe or rod so that it is aligned in a northerly-southerly direction for a period of time can result in a residual magnetic field. Once again the affect is strongest in the northern and southern latitudes.
Preparing the ends for welding can sometimes induce a residual field in the pipe and the welding of the longitudinal seams may induce a field in the pipe, but in that case the residual field is most likely a circular field.
Carbon and low alloy steels with high carbon equivalencies tend to have lower permeability and tend to be harder to magnetize, but once they are magnetized, they retain the magnetic field more so than softer lower strength steels.
Wrapping DC leads around the pipe may work, and is sometimes done in the pipeline industry but it typically only loweres the magnetism while the DC current passes through the leads, but does not remove it.
Another option would be to try connecting welding leads to each end of the pipe. Then run AC current (start at 100 amps)through it for several minutes. This should break up the polarization of electrons that is causing the magnetism in the pipe. This technique is often used for demagnetizing of welding fixtures that have become magnetized due to the constant unidirectional movement of electrons from DC current, which leaves the electrons in the fixture aligned in a manner that polarizes the fixture.
