Up Topic Welding Industry / General Welding Discussion / SA200 Short Hood Mag
- - By Rex Theobald Date 06-10-2009 19:25
I am replacing a mag on a 200 short hood. I have found the timing marks on the gov, but can't find then on the gear that drives the mag/gov. How else can I time machine?
Rex
Parent - By FixaLinc (****) Date 06-14-2009 20:13
Sometimes can't find those marks or flywheel mark either.  Pull plug on #1 by radiator and get it up on compression stroke.  The mag drive slots should be a tad bit off horizontal.  FM mag put rotor on #1 upper left or Bosch #1 upper right tower.  Timing order 1-3-4-2.  Adjust later with timing light if can find the flywheel mark.
