Up Topic Welding Industry / General Welding Discussion / PORTABLE POWER CONVERTER
- - By Dale Gerstel (*) Date 06-11-2009 14:10
I just bought a MILLERMATIC 180. I am looking for a portable convertor or a reasonably priced generator that will put out enough ampss.Its 230 v I'm looking for.
Parent - - By DaveBoyer (*****) Date 06-12-2009 03:10
You need a generator that can handle a 22 amp inductive load. Note that most portable generators are rated for a resistive load, so a 5 KW generator may not run the machine properly, You might need a larger one.
The battery requirements to run this welder from an inverter are pretty severe, I wouldn't go that way.
Parent - - By Dale Gerstel (*) Date 06-12-2009 15:30
THANKS, I APPRECIATE INFO.I DECIDED TO RETURN MY MILLERMATIC 180 FOR THE NEW 211.THE NEW 211 HANDLES 120 AND 230.
Parent - By hillbilly (**) Date 06-13-2009 03:09
sounds to me like you should return your 211 for an engine drive. do you have to run wire in the field or is it a personal choice? Wire is fast, but it seems like your putting the cart before the horse, electric welder vs. power supply...
Parent - By DaveBoyer (*****) Date 06-13-2009 05:05
If You want to run wire in the field, Miller does make a small engine drive CV machine for field MIG welding, it might suit Your needs better. I wouldn't expect real good performance from any machine on 120 volts, just not a lot of power to work with.
