Up Topic American Welding Society Services / Certifications / fiiler metal dia. limitations for welder certifications
- - By natecf (*) Date 06-11-2009 15:16
Are welders certified to a wps for .035 wire gmaw spray,automatically be certified to a wps for .045 wire ,if thier qualification test was done with .035 wire?   D1.1 2006 has no requiremants under essential variables for welder performance (4.22) I know filler metal diameter for a wps is an essential variable requiring requalification, not sure how wire size affects welder quals.
   any thoughts would be appreciated. thanks
Parent - - By Lawrence (*****) Date 06-11-2009 16:23
Nathan
A welder qualified in spray transfer GMAW is qualified to weld any filler diameter.
There are however WPS limitations,  so even a prequalified WPS may need to be revised if a wire diameter increase is involved.
Parent - - By natecf (*) Date 06-11-2009 16:39
thanks for the reply, that makes sense,just couldn"t find specific language to say one way or the other
Parent - - By Bill M (***) Date 06-12-2009 19:28
We are a heavy equip. manufacturer.  Although not code required, our internal welder qualification program had FCAW dia limits.  Welders using our 3/32" dia wire are required to qualify separately with that dia.
Parent - By natecf (*) Date 06-16-2009 14:10
that makes sense, I'm suprised that there is no requirement in D1.1. go figure
