The simple answer is no. The difference in wall thickness must be at least 4.8 mm between the thinner wall (13 mm) and the thicker wall.
You can use 6 inch schedule 120 and schedule XX strong as one combination or you can use 8 inch schedule 120 and schedule XX strong for another combination. Clearly you can't use 6 inch and 8 inch together.
