I think it was 37.5 on the bevel. They are machined, you just put your land on, they fit it to nickel gap and you use 5/32 for the bead. Bryan said the rest, and they cut your straps and bend and break. Just take your time, bunch of good guys to help you out.
Good luck, see you on the line
