Hello Erik, I believe the short answer is that in some cases there can be a delayed cracking issue with some materials and joint configurations. I am sure others can give you a more concise answer, yet I believe I have covered the main reason. Best regards, Allan
Erik,
Do a search here on the forum, it has been discussed many times before.
You can also do a google search for the term "delayed cracking" that should keep you busy reading for a long time :)
3.2
