Up Topic American Welding Society Services / Technical Standards & Publications / Heat Input Formula Question
- - By eekpod (****) Date 06-24-2009 18:24
I have an algebra question regarding the Heat Input Formula thats in D1.5 on pg 89.
"Heat Input shall be determined using the formula:"
Heat input (Kilojoules/in.)= Amps X Volts x 0.06 divided by Travel Speed (in/minute).
Question, the travel speed (in/minute) is that another formula (inches welded DIVIDED by minutes) or is it inches per minute welded?
I'm having trouble with my calculations coming out in the correct format, and I'm not big on math, any help would be greatly appreciated.
Chris
Ex. SAW 300Amps 30 volts 24" weld took 1:33 (one minute 33 sec.)
Parent - - By jwright650 (*****) Date 06-24-2009 18:30 Edited 06-24-2009 18:38
Chris...if you divide the 24" by 1.5 minutes(1 minute and 30 sec) you get 16 ipm
24" in 1:15(1.25 min) = 19.2 ipm
24" in 1:45(1.75 min) = 13.7 ipm
24" in 2 minutes flat  = 12 ipm
Parent - - By eekpod (****) Date 06-24-2009 18:59
OK, so it is another little formula I have to do before I plug it into the main formula.
Or said another way, I take my inches welded and divide by the time, take that answer and divide it into the numerator sum and I'll come up with the Kj/ per inch.
24" welded took 1:33 is 24/ 1.55= 15.4 in per minute.. then take that and divide into 330A X 30V X.06= 594
so 594 / 15.4 in per minute =38.5 Kj/ in.
sound right?
Parent - - By jwright650 (*****) Date 06-24-2009 19:08
I didn't run back through your math, but that end result looks about right.
Parent - - By eekpod (****) Date 06-24-2009 19:29
I'm not familier with these values so I can't look at and tell if it's good or not.
Where does the .06 come from? any idea?
Also, thank you for your help.
Chris
Parent - By CWI555 (*****) Date 06-24-2009 20:26 Edited 06-24-2009 20:34
Some formula / by 1000, .06x1000 =60 or 60 minutes. To move the decimal. .006 or 1000's of 60. it's just a short cut.
Parent - By drewp29 (**) Date 06-26-2009 20:16 Edited 06-26-2009 20:27
1Amp x 1Volt = 1Watt = 1Joules/1second
converting the seconds to minutes to account for constant units with the Travel Speed (inches/min)
1Joule/1second x 60seconds/1min = 60joules/1min --> now changing the Joules to Kilojoules --> 60Joules/1min x 1kJ/1000Joules = .06kJ/1min which becomes our multiplication factor to account for consistent units in the original equation.
Thus,
Amps x Volts (J/s) x .06 (to convert to kJ/min) / TS (in/min) = HI (kJ/inch) --> the minutes end up in numerator and denominator and cancel each other.
Ahh, conversion factors . . . great for shortcuts, but when you don't know why they are applied they can be pretty confusing.
Drew
Parent - - By 803056 (*****) Date 06-24-2009 19:38 Edited 06-24-2009 19:48
Heat Input = V x A x 60 / TS
Voltage times Amperage times 60 / Travel Speed (ipm) = heat input in joules per inch. Divide by 1000 to get kJ/in.  Where travel speed equals:
Length welded divided by the time taken to weld the joint, so: (Length welded/ (minutes times 60 plus seconds to weld the length welded)) = travel speed in inches per second. Now multiply by 60 to get travel speed in inches per minute. Therefore the equation can be written as:
(V x A x 60 / (L/(m x 60) + s) x 60) / 1000 = kJ/in.
Where V = voltage
A = amperage
60 is a constant
L = length of joint welded
m = minutes
s = seconds
kJ = kilojoules
Your example:  300A x 30V x 60 / ((24 in/(93 sec)x60) / 1000 = 34.875 kJ/in. (there may be differences due to rounding errors or I could be wrong with my number crunching)
Hope this helps.
Parent - By eekpod (****) Date 06-29-2009 10:48
Sorry I didn't folow up, its been real busy getting ready for my audit.  Thank you for all your input everyone.  The first time I did this, I incorrectly figured the travel speed, and my values were way out of wack.  I'm all set now.
