Any possibility of only letting your best welders use the ultra core? If you let the most concientious welders use the ultracore, you might eliminate 50% of your field reworks.
Put the best on any difficult-to-repair welds. Might cost you a .25 cents an hour premium for ultra-core welder. Then again, it might not be worth using ultracore.
Good luck.
Jeff
